Over the last 5 months my mpg’s have dropped. I’ve lost about 2.5 mpg.
Recently did new thermostats, fuel filters, air filter, pitman, idler, alignment and they haven’t came back any. Last I checked codes I didn’t have any. What else should I check?
Are you running fuel additives?
Have you changed fuel sources?
Do you get fuel from a discounter?
Changed tires? Lift or level change?
Been leveled with roughly the same size tires, run opti summer and the same gas station the whole time. I thought the new thermostats would help now that I’m running at temp.
I see your in Idaho, are you guys running winter diesel already? MPG tends to drop on winter diesel since it has a lower energy density than summer diesel, thus you must burn more for the same power. May not explain the 5 month trend but it might explain any recent drops. Otherwise there are so many factors that impact mileage it would be nearly impossible to cover them all.
Checked my balance rates, all were within 1% -1 to 1. Ran opti lube injector cleaner through also. Cleaned the maf. My last tank came out at 14.4 mpg running on flat ground with no load.
