ok guys, really need some help here. Sorry if its long, but i really want to fix this. i have searched all over the DF and others, with no luck. i cannot, for the life of me, figure out why my temp gauge going crazy! i have found a few other threads with people having the same issues, but not one solution for it(many guesses).
heres the issue-
the temp gauge will fluctuate from side to side, 160 - 260, very erratic and random. and DIC will say "coolant hot"/"engine overheated"
it doesn't matter if the truck is warm or i just started it first thing in the morning.
seems to do it mostly at idle or when i let off the throttle, but it is random and will do it cruising on the highway as well.
when it is happening the idle seems to jump around (~100-200rpm's) and the truck sounds rough.
here is what i have done to try to fix it-
changed the thermostats, full coolant flush, new overflow cap, new temp sensor, new temp sensor plug and leads, i've bled it many times, checked and cleaned grounds(read a thread that suggested this), and next step i have a MA water pump i was gonna throw in this weekend.
each time i do something it seems to make it go away for a few weeks, but then comes back.
i have checked the FCM harness to see if maybe it was that with no luck. no codes come up and i don't know what to do next, really desperate here!
i have some videos that may or may not help, anyone who has had this or seen this, please let me know how you fixed it!
(if someone could help with how to post the videos i will they are .MOV files)
thanks for any input!
heres the issue-
