I had the infamous filter head leak happen with my 30ft horse trailer hooked up and the whole rig parked in front of the driveway. I was able to fix it on the cheap for $.72 The O-ring from Lowes has been working for 2 weeks. Yesterday the new set I ordered from O-ringCity.com was im my mailbox. Only $10 for the basic kit. Before i installed the 4 new o-rings, I tested the one from Lowes by pumping the primer. As it got hard to push, my cheap fix held but the o-ring around the heater terminal failed. Thank you for encouraging me to get the kit.. Although the one on the breather bolt was fine. The two under the heater were in bad shape. Took me only half an hour and that was only because I didnt have the right tool to remove and replace the hose clamps. I love being able to fix my own truck. Next will be a brake inspection. I know I have lots of life left in the pads but need to check the roters a little closer. Are there any points I should make sure to cover? Thank you. Tim
