i noticed today when i got on it that my boost stopped at 22 psi. Its normally goes to 26 or 27. Engine was fully warmed up. still runs fine. Any ideas?
a stock turbo only goes around 20, with the boost increse valve its like 28-30. Normal things, start checking for boost leaks, maybe you got a hole in your line to your gauges...
Turbo might be bad
Banned
If your using the edge to read it, the stock boost pressure sensor only reads up to 22 psi on an LB7 and LLY, so that is right.
Are you stacking an Edge with a Bullydog?
