Low coolant light always on.
29K views 15 replies 8 participants last post by  Harold 66
ever have a puddle under the front of the truck??? see any coolant coming out of weep hole on water pump??? possible head gasket..
my coolant is low light has been on for months and i saw a thing on utube about a possible fix so i tried it. removed the tank (and wiring), dumped out the nasty water in it and used "dawn" or whatever dishwashing liguid you have and partially filled with water and shaked it around a bunch. repeat a time or two. then you can hear the sensor click as you turn the tank right side up and up side down you have succesfully cleaned it. my light went off after i did this. NICE no money spend, problem gone.
#4 ·
None of the above... Literally the only thing is it comes on when I start the truck. Says low engine coolant. It has plenty in it every time I've looked and no leaking. Oil isn't milky or anything.
More Anoying than anything.
i wonder if the low coolant level sensor is bad
Damn what's the stealership gonna get me for there.
