CTduramaxed.... i've got bad head gaskets. dealer put in dye, pressure tested it and pulled glow plugs. first issue was found on cylinder #3. after that, they stopped and have went forward with pulling the cab and ordering parts. I went by the dealer and checked everything out after it was all torn down. the black/grey flakes in the coolant were a part of the gasket, could scrap it off the gasket with my finger nail. GM Tech support noted some bad gaskets from the manufacturer, where granulations got in-between the layers of the gaskets when they were made, causing bad gaskets. not sure if that is 100% the issue, but I hope so. Dealer is also sending the heads to a shop tomorrow to have the decks checked. Hopefully she's good to go after the fix. good luck to you as well.
