1 - 20 of 57 Posts
if this in the wrong place sorry guys.
so today i got off work an went to town an on my way back the low coolant light came on the message center. I've checked the oil, its not milky and ive looked everywhere under the truck and nothing wet what so ever. please tell me this coolant is just vanishing into thin air.
It may be seeping out from the EGR cooler and the motor heat is evaporating it. Or it could be leaking out through the hole on the bottom side of your water pump indicating the meachanical seal in your water pump is starting to go out. Look underneath the center of the motor and see if you can see any trails of liquid evaporating.
no egr, 01 lb7
ill check it in the morning, thanks kyle
did you physically check to see if you are low on coolant and it isn't just your sensor acting up?
Discussion Starter #7
i didnt. i think you might be right because i ran it pretty hard today trying to make the light come on and it never did, but it was also 25 degrees cooler today
I'm That Guy...
First thing you should do or have done is check coolant level.
Discussion Starter #9
that shit is hot tony! an there is absolutely no way to vent the pressure off lol
I'm That Guy...
Lol, you can't see through the side of the tank?
How is the fluid level when it cools down?
How many miles are on your truck??
Discussion Starter #12
168000
Discussion Starter #13
im going to check it in the morning if i remember
Well did you check the level?? and the hose to see if it was hard?
Discussion Starter #15
its a little low, the hose was hard this morning. a little harder then a tennis ball. how the fuck do you get in the reservoir open without the antifreeze going everywhere
Discussion Starter #16
anyone?
I'm That Guy...
Open it when it's cold.
Go buy a cap and replace it, cheap attempt to fix it.
Are you opening the over flow cap or the radiator cap??
and also, don't open it when it's hot.
you can go ahead and kiss the theory that your sensor is bad out the window though.... because even if it was just your sensor, you are definitely low on coolant now since you sprayed it everywhere by opening a hot cap.
Just take it to a mechanic.
Discussion Starter #19
ok i finally got to park it on concrete overnight. theres a puddle of antifreeze between my engine and tranny. what would leak clear back there or could it run the far from the water pump before droppin? if it was head gaskets i wouldnt have have a puddle of antifreeze would i cuz that would all stay in the engine right?
Discussion Starter #20
1 - 20 of 57 Posts
