1 - 11 of 11 Posts
im not sure if i put this in the right forum, correct me if its not. Anyways, for the last while my trucks oil pressure has been worrying me, when its cold at idle its sits about 400-450 kpa, normal isnt it? but when its warmed up in gear or not, it sits at about 190kpa at idle, and about 400kpa at 1500rpm, give or take. ive just changed the oil, its full, and has always been, i always check it to make sure. and im running 15w40. does anyone no of an easy way to diagnose a problem? where to start etc? any advise is appreciated. thanks
sounds normal to me.. i did calculations
your saying its around 27 at idle. and 60 going? that sounds about normal to me
yep thats what i mean, i was never really sure what was normal and it sure seemed low to me. thanks!
EVERYONE with a Duramax has been concerned about the oil pressure on their truck at one time or another. However, very few have ever had a engine problem traced to low oil pressure.
The oil system is high volume, low pressure.
Banned
When your oil is cold the pressure is higher around 60, once it warms up the pressure drops to around 25. This is why fueling a cold diesel is bad, oil pressure skyrockets bc the demand is exceeding supply which means your not lubricateing your engine properly. Let diesels warm up completely before getting on them..........
OP, your truck is fine...................................
The oil is thicker when cold, and is not pushed through the bearings as easy. That is why the oil pressure is higher. IMO
So what pressure would you wait to see before you begin driving after first start-up?
In my opinion, it is OK to start up the vehicle and drive-- BUT keep the RPM at, or below 1,000, by driving slow. This will help it warm faster and will not hurt the drive train.
I would never start it, and beat on it!
Not just for a diesel buy anything that is lubed by oil! the colder it is the easer you go on it. It kills me to see someone start up something up cold then rag on it
1 - 11 of 11 Posts
