1 - 13 of 13 Posts
A friend borrowed my 2007.5 2500HD today and despite my telling him to only put in ultra-low sulfur diesel he pulled into a Valero and put in about 10 gal of low sulfur. He called me and I told him to stop pumping and he's going to go to another station and fill the rest with ULSD. Is there a risk of damage with that amount mixed in?
Thanks...I normally add Diesel Kleen at each fillup and I had him do it as well. From what I understand the LSD won't harm the motor at all, but it can cause the DPF to clog up quickly. I'm just hoping that 10 gal isn't enough to cause an issue.
you lucky i am looking for pumps that just sell low sulfer
HUH !! I did not know you could still purchase "LSD", I thought it has all been converted over to "ULSD" ???
Or, does it depend on your location ?? I guess it could still be available !!
I am sure it was ULSD-- that is a fed requirement for on-road diesel fuel-- for about 5 years. If you did use LSD for an extended time, it could mess up the DPF, but if it already fell off, there is no problem what so ever.
NewEST Spinny Thinggg
^^^exactly unless it was farm diesel (dyed) its ulsd...most places still just have the LSD sticker on the pump still
their are a could places around me that still sell it. its like a thirty mile drive though. it is lsd...the prices is about 10c higher per gallon
VAGITARIAN :)
still available depending on location.......I can roll BIG,BLACK clouds of smoke with lsd too...I don't worry though I have a LBZ and it is fine with it...no worry unless your putting a lot of lsd fuel into it.:drink
THE PROBLEM IS NOT WITH NOT ENOUGHT LUBRICATION. The problem is the dpf CANNOT have anything other that ulsd go through it. If it goes into regen with normal diesel in it, it may melt the filter. Seen it before at my dealership, and they are REALLY REALLY REALLY EXPENSIVE. DO not let it go into regen mode until you get that crap out of their.
1 - 13 of 13 Posts
