21 - 24 of 24 Posts
Are you sure its coming from the lower pan and not the upper?
Reactions: cfell
Discussion Starter · #22 ·
Hi, thanks for the reply's. I will probably follow the procedure of waiting for the RTV to firm up. Yes I'm sure its not the upper pan. I used dye in the oil. You can see its coming from the edges of the lower pan. I read somewhere and of course cannot find the thread about someone having a defective pan. Almost thinking somehow I do?
You know... since you have one of the bolt holes stripped out, is it possible it is leaking around that bolt hole you repaired?
Discussion Starter · #24 ·
I thought about that. Its not leaking in that area. I was able to tap the hole with the next size up threads and get a bolt in there. It pulled nice and tight and was able to torque it. I honestly think at this point, I'm going to just bite the bullet and put a PPE pan on and see what happens.
21 - 24 of 24 Posts
