1 - 12 of 12 Posts
Anyone using any of their fuel treatments and if not are there any that are worth using?
You could not pay me to run that crap in my truck:drink
Here is the Lubricity study done on another forum. Lucus was worse than running nothing at all:eek:
In Order Of Performance:
1) 2% REG SoyPower biodiesel
HFRR 221, 415 micron improvement.
50:1 ratio of baseline fuel to 100% biodiesel
66.56 oz. of 100% biodiesel per 26 gallons of diesel fuel
Price: market value
2)Opti-Lube XPD
Multi-purpose + anti-gel
cetane improver, demulsifier
HFRR 317, 319 micron improvement.
256:1 ratio
13 oz/tank
$4.35/tank
3)FPPF RV, Bus, SUV Diesel/Gas fuel treatment
Gas and Diesel
cetane improver, emulsifier
HFRR 439, 197 micron improvement
640:1 ratio
5.2 oz/tank
$2.60/tank
4)Opti-Lube Summer Blend
Multi-purpose
demulsifier
HFRR 447, 189 micron improvement
3000:1 ratio
1.11 oz/tank
$0.68/tank
5)Opti-Lube Winter Blend
Muti-purpose + anti-gel
cetane improver
HFRR 461, 175 micron improvement
512:1 ratio
6.5 oz/tank
$3.65/tank
6)Schaeffer Diesel Treat 2000
cetane improver, emulsifier, bio-diesel compatible
HFRR 470, 166 micron improvement
1000:1 ratio
3.32 oz/tank
$1.87/tank
7)Super Tech Outboard 2-cycle TC-W3 engine oil
Unconventional (Not ULSD compliant, may damage 2007 or newer systems)
HFRR 474, 162 micron improvement
200:1 ratio
16.64 oz/tank
$1.09/tank
8)Stanadyne Lubricity Formula
Lubricity Only
demulsifier, 5% bio-diesel compatible, alcohol free
HFRR 479, 157 micron improvement
1000:1 ratio
3.32 oz/tank
$1.00/tank
9)Amsoil Diesel Concentrate
Multi-purpose
demulsifier, bio-diesel compatible, alcohol free
HFRR 488, 148 micron improvement
640:1 ratio
5.2 oz/tank
$2.16/tank
10)Power Service Diesel Kleen + Cetane Boost
Multi-purpose
Cetane improver, bio-diesel compatible, alcohol free
HFRR 575, 61 micron improvement
400:1 ratio
8.32 oz/tank
$1.58/tank
11)Howe’s Meaner Power Kleaner
Multi-purpose
Alcohol free
HFRR 586, 50 micron improvement
1000:1 ratio
3.32 oz/tank
$1.36/tank
12)Stanadyne Performance Formula
cetane improver, demulsifier, 5% bio-diesel compatible, alcohol free
HFRR 603, 33 micron improvement
480:1 ratio
6.9 oz/tank
$4.35/tank
13)Used Motor Oil, Shell Rotella T 15w40, 5,000 miles used.
Unconventional (Not ULSD compliant, may damage systems)
HFRR 634, 2 micron improvement
200:1 ratio
16.64 oz/tank
price: market value
14)Lucas Upper Cylinder Lubricant
Gas or diesel
HFRR 641, 5 microns worse than baseline (statistically insignificant change)
427:1 ratio
7.8 oz/tank
$2.65/tank
15)B1000 Diesel Fuel Conditioner by Milligan Biotech
Multi-purpose, canola oil based additive
HFRR 644, 8 microns worse than baseline (statistically insignificant change)
1000:1 ratio
3.32 oz/tank
$2.67/tank
16)FPPF Lubricity Plus Fuel Power
Emulsifier, alcohol free
HFRR 675, 39 microns worse than baseline fuel
1000:1 ratio
3.32 oz/tank
$1.12/tank
17)Marvel Mystery Oil
Gas, oil and Diesel fuel additive (NOT ULSD compliant, may damage 2007 and newer systems)
HFRR 678, 42 microns worse than baseline fuel.
320:1 ratio
10.4 oz/tank
$3.22/tank
18)ValvTect Diesel Guard Heavy Duty/Marine Diesel Fuel Additive
Multi-purpose
Cetane improver, emulsifier, alcohol free
HFRR 696, 60 microns worse than baseline fuel
1000:1 ratio
3.32 oz/tank
$2.38/tank
19)Primrose Power Blend 2003
Multi-purpose
Cetane boost, bio-diesel compatible, emulsifier
HFRR 711, 75 microns worse than baseline
1066:1 ratio
3.12 oz/tank
$1.39/tank
The Good Son!
I wouldn't run anything below Diesel Kleen (#10) on the above list. I would only run diesel kleen if I was desperate and not because it is a bad product but, because there are so many additives superior to it. JMO
Thanks for the info, Is one type diesel fuel better than another?
Discussion Starter #7
Thanks again for everyones comments. Heard of "Diesel Secret Energy"?
Red is the best IMHO untill you get caught :D
I only use 2 stroke oil every now and then, but mainly diesel Kleen and over treat the crap out of it.
Yep, I usually put the 40 gallon bottle in a new tank of gas. Not quite 2:1 the regular dosage, but it's overkill. Runs like a top when I do this.
I have used #5, #7, #10, #13
I can say that #5 was the best, things were smooth and quiet with OptiLube. DieselKleen is just so easy to get though.
I do run a mixture of 14oz lucas with 18oz diesel kleen (silver bottle) mixed in a 32oz bottle.
I`ll put in 12oz-16oz pretty much every tank full.
I will have a increase of at least .5 - 1 mpg, compaired to when I don`t add my mix.
I do top off and hand calculate everytime I fuel up.
I have used this mixture since 2003 on 2 of my personal diesels, and never any issues, only good results. :rockin
Lucas also works great in carbureted and older fuel injected gassers.
Lucas also acts as a fuel stabilizer it works great for the vehicles that set alot.
My class A gasser motorhome only gets out twice a year and I have never had a fuel issue since I started using Lucas fuel treatment 5 years ago, including the gen set no issues.
Mileage is up 1 mpg 5 1/2 to 6 1/2 average and I have owned my gasser motorhome since 1995
so u can run pre mix
can anyone give me some details what kind and how to mix
It depends on what you are asking for.
If you are refering to the mix I stated on my reply # 10, the mix I use and how much I use, is explained on that reply.
1 - 12 of 12 Posts
