1 - 12 of 12 Posts
hey guys, i need some advice, i just dropped about 600 bucks on the magnaflow exhaust system. I got the 4 inch pipe from the cat back and a 5 inch chrome tip. I got to tell you it looks really nice with that 5 inch tip thats almost 2 feet long but the sound is not what i expected. dont get me wrong it sounds deeper but its not loud at all! you can hear it a little bit if i gun it but then i literally watch my gas gauge drop when i do that!:confused: I thought it would be pretty loud considering my bro's has the same thing on his powerstroke but i guess not, any ideas to make that baby scream, i mean i want people to just go DAMN when i fly by them you know...appreciate any help or ideas you guys have, thanks:help
Hi, I'm Earth. Have we met?
Since it has a cat i assume its a lly, right? TO get any sound from a lly you must remove the cat and the muffler! The tight turbo exhaust housing of the vvt really cuts down on the exhaust sound!
its a 07 LBZ
ok, the lbz has the vvt also, Remove the cat if you want it louder, and if thats not enough you have to loose the muffler! and if thats not enough you might have to look into a fixed vane turbo but no cat and no muffler should be loud enough!!
I have a customer here with an 06 LBZ with MBRP duals and we are going to be pulling the muffler out cause its way to quiet. Ca is gone, MBRP muffler, still to quiet. Just straight pipe it and get it over with!:fart
Diesel Addict
i don't mean to tell you what to do,but put a straight on it or if you want the loudest avalible then go with a 5" turbo back.a friend of mine has a 06 cummins with the stock pipe made into a straight and my 06 lbz with the 5" magnaflow turbo back screams louder then mine friends cummins.
thanks for the info everyone i appreciate it, now without the muffler what does it sound like or sound similar to?
I have an 07 lbz with 4 inch turbo back MBRP with no cat and it still is not very loud but you get that cool sounding turbo whine. There is not much to the MBRP muffler so a straight pipe might be what you are looking for if you what it louder. Remember the Duramax is a superior motor to the Cummings and Powerstroke it will always quieter and smoother.
yea thats funny you said that because it seems like since i got the new exhaust system that the turbo got alot louder, i dont know if its my imagination but i swear i can hear it alot more?? does anyone know if you can put a blow off valve on our turbos, by buddy had one on his eclipse like 10 years ago and i remember it sounded cool when he shifted gears, it was a Greddy...anyone have one on their truck?:rockin
You can buy just the straight pipe from the turbo to your exsisting magnaflow system from them or other high performance exhusts sytems for around $100 bucks. Better yet if you have friend at a muffler shop that will make you one. I would take the cat off first. I do not know about blowing the valve off but more than likely you will be doing your turbo a favor by lowering egt's.:cool:
A blow off valve really would not do anything as there is no butterfly in the intake closing to cause a sudden surge in boost in the intake!
1 - 12 of 12 Posts
