1 - 8 of 8 Posts
I have used manual mode before and tonight I used it and had the screen on SELECTED RANGE: M5. I was going on long flat run and bumped it up to 6th and the screen went back to (6) 5 4 3 2 1.
The last time I used it I could have sworn it stayed on SELECTED RANGE: M5 and when I changed it SELECTED RANGE: M6, not back to the numbers 1-6.
This time i was just pulling a 1000 pound trailer and my chemical tank with about 100 gallons in it.
I even put it in tow/haul mode and then had the SELECTED RANGE screen up and manually changed it and it still went back to the numbers.
Am I correct about it not changing the screen by itself or am I loosing it?
mine shows the numbers as well
so you've never shuffled through the screen functions and seen "SECLECTED RANGE:M and whatever gear your in?
ive never seen that mines always been just numbers
just numbers here.
If you change the dic like go in to the fuel filter life or something it will go to M5 or some gear. If its on the blank dic screen in will go 1 through 6.
1 - 8 of 8 Posts
