1 - 13 of 13 Posts
whats the difference in the pro xp and installer series? does it take a lot of work to bolt these things on? it doesn't seem like it would be that hard but im just wondering
Discussion Starter #2
also is there any advantage in getting a 6in tip over a 5in tip with a 4in system?
Diesel Addict
it's all about the look..bigger the better or thats what i was told:drink:rockin5" will do but the 6" has killer looks.
thats what i thought
i just thought it might help with exhaust temps like those little slits on the 08s exhaust
Diesel Addict
i found out that a 4" exhaust runs cooler(lower egt's)then a 5" with the stock charger,it's almost like the bigger pipe it loses volocity and kinda stays in the pipe longer instead of shooting out the rear of the pipe like it would with a smaller pipe..just my experience
2016 GMC Denali HD 6.6, Leveled, 35x12.5 Ridge Grapplers on Stock Wheels
that would make sense, plus 5" will probly give you more backpressure popping!
Discussion Starter #8
how would the 5" have more backpressure? isn't it more open and unrestricted than a 4"?
Diesel Addict
well it's hard to explain so let me try again,with a bigger pipe it lose velocity and therefore it case some engine discharge to build up inside the pipe and that would add more restriction for the turbo to push it out and in the end your egt's are higher..
now guys this is not based on a rocket sciencetist philosophy just a average guy doin some experimenting..
Discussion Starter #10
alright that makes sense does anyone know the answer to my first post on this thread
Diesel Addict
like i said thats is what i came up with(i might be wrong)and it isn't back by anything other them my thoughts..
I am not saying you are wrong either.
Sometimes there are other things at work that make a difference.:drink I can't think of what that would be.
1 - 13 of 13 Posts
