41 - 47 of 47 Posts
What is this sensor(marked w/arrow) on the LML and will I have issues by installing my nozzles in front of it?
Thats the MAP sensor, you'll be fine putting the nozzles in front.
We verified on the dyno at Jag's Performance that the Snow Boost Cooler system running 49% meth was good for 60HP.
First off thanks for sharing WhiteHD11, thats great to hear you saw some good results. I have been thinking I want put a kit on my truck. What model did you go with for snow kit? and what else do you have done to the truck? Last is did you do any tuning changes or just add on top of what you had? Thanks in advance
Very nice truck I may be following some of your other ideas as well. And I was just curious if you had kory adjust anything or if it was 60hp over just adding the meth without any tune adjustments. I have been running the max effort most of the time as well, but figured with the meth and driving sensible one could tow and do it all with out even changing tunes. That is what I would like anyway :D
Sent from my SM-G930V using Tapatalk
41 - 47 of 47 Posts
