1 - 14 of 14 Posts
I got 05 lly that been wrecked, it does crank, but someone pulled mass airflow sensor out. I checked and there is no fuel coming through prime screw, so im wondering if missing airflow sensor would have to do something with that?
Yeah there isnt any in the fuel filter, its got half a tank. Im not sure if missing airflow sensor prevents it from getting fuel. Also is there a fuel shutoff switch on those trucks?
yes it is sticking up right next to the bleeder screw! loosen the bleeder screw then press the button down alot until you get fuel out
there is no lift pump, that is why there is no fuel at the bleeder screw. the entire system is under vacume, it is going to be tough to start im sure there fuel system is full of air now.
Slave to the Interwebs
I just had a buddy here take a wrecked Dmax and a blown Dmax and make one. He was playing musical trucks with all the parts floating around. Need any body parts??
it will run but you won't get any power out of it without the MAF sensor.
1 - 14 of 14 Posts
