So, about a month ago I added a catch can but returned the output back to the intake. The theory was to remove any luqiuds, but still allow the air to enter the engine.
http://www.duramaxforum.com/forum/performance-upgrades/107144-lbz-pvc-re-route-correct-way.html
When I did this, I cleaned up the previous oil in the line to the inter-cooler and temporally used clear tubing to the catch can so I could monitor the in and out to make sure I was catching everything.
Well....after a couple thousand miles, I haven't caught anything because I haven't pulled anything. Both tubes are clean as a whistle, nothing.
I believe what has happen is that because I mod'd my airbox and removed a lot of the restriction, I've lower the vacuum level for the PCV to the point where there's not enough force to raise and pull fliuds anymore.
So, I think the moral here is that if you have a less restrictive airbox of some sort, and a clean filter, a PCV re-route would be a waste of time and money...I guess.
