1 - 11 of 11 Posts
What would I set my vane positions at to be able to hear my turbo. I
Mean I want it to sound like a jet. Just at idle and easing in to it.
I know brian (hondarider) has messed with this. he'll know what tables you need to mess with i believe. he said he'd been able to make boost at idle, only problem was egt's were about 450* and i imagine he did worse on fuel.
With my bigger turbo it shouldn't take much.
Set Turbo Vain Target Position to 79-80 in area mm3 5-20, RPM 600 to 1000 (Top Left Corner)
ok easy, how do I change it on all my tunes? just do 1-4 tunes and then save?
Does this make it sound like an aftermarket turbo? Or just how it sounds stock?
just sounds like a jet/hiss
I set it to what you said and its not much louder. is there anything else I could do like make it idle a little higher or something? I heard a lmm and it sounded mean with stock turbo, and sounded like it was idleing a little higher couldnt tell really just heard nothing but whilste, even when he was in drive not pushing the gas
1 - 11 of 11 Posts
