Guys I just had exhaust, lift pump, and motorops SOTF tune installed and it doesn't feel like it pulls as good as it did when I had a canned edge evolution tune. What gives? 0-60 times dropped off too. Any help is appreciated
Discussion Starter · #2 ·
Also, I noticed my max boost is only 32-33 psi which is less than I was getting before
19 Denali L5P SOTF Tuned. PLUS lots more
Where do you start with a post like this? If it's deleted there's no help here. If a tuner done it I would go straight back to them. Otherwise start checking between turbo and engine to find the leak.
Administrator
You can contact your tuner, but I would bet they would ask you to test your system for boost leaks to start. DuramaxTuner sells some cool adapters to test for boost leaks.
Next step will be data logging.
Reactions: Melonhead1102
