While driving around the 25-45 mph range if I lay into the throttle from cruising the motor will rev up and spool the turbos as normal but the truck doesn't take off as it should. It's like there is a hesitation in the driveline somewhere. After a second or two the power makes it through the driveline and to the ground. The truck has the transmission and converter in my sig. Anyone having similar issues or know what the cause could be? Only hesitates from this speed. From a stop it's fine and after the converter locks it's fine.
What's rail pressure & boost doing when this happens?
Have not looked at rail pressure during but boost is around 40psi
