I have a 2007.5 crew cab long bed 2WD 6.6 with the Allison 6 speed. The truck came with the small 245/75/16 tires. I want to put a little bigger tires on when these wear out. Is the truck set up to run this size for the best mpg or can I go a little bigger and not hurt mpg? I plan on keeping the rims. Thanks
Anytime you go up in size you will drop your fuel mileage a bit. I went from 245s to 285 and they look a lot better, kinda wish i would have gone with 265s to get a bit more mileage.
Administrator
also, you speedo should be correct with the 265s without any programming. It seems that most trucks show faster than you are really going with the 245s....at least mine did.
