1 - 11 of 11 Posts
Hey What Kind Of Aftermarket Muffler Can I Run Without Changing My Stock Pipes? Any Suggestions And Websites Would Be Helpful
Thanks.....
I think flowmaster makes a muffler for diesels. Check out summitracing.com. Almost any offset muffler with 3 1/2" in and out will work. You could also just straight pipe it too.
i looked for mufflers that were 3.5 and the 2 muffler shops i went to just had the 4 inch, they didnt have 3.5, might have to special order it online.. i had to end up putting 4 inch piping from the cat back...good luck:drink
Smoke. It's what's cookin
If you lose the Cat and put a 4" system on it will help lower your egt's and the turbo spools a little quicker in my opinon. Or you could even go with a 5" system. Goodluck.
Ryan
Diesel Addict
i put a straight pipe on using the stock pipe and it did a great job,but that didn't last very long untill i had to have a 5" turbo back exhaust...good luck there
Hi, I'm Earth. Have we met?
MBRP Makes a muffler delete pipe for the stock exhaust, usually can find them for less than 100 bucks!
Do You Remember How You Got To That Ebay Site, Maybe The Same Dealer Has Another Set..
Thanks
Diesel Addict
I put on the silverline 4" system and love it. I didn't want it too loud. I've got the muffler in but i put it on backwards and it gave it a little more tone then the restrictive correct way.
1 - 11 of 11 Posts
