:help I had the edge c/s programmer on and it was freezing relatively frequently and then one day when i started it the truck was chugging loudly and shaking which is NOT normal so i let it run a minute, tryed turning it off and back on and it was the same. then i put it in drive just to see and it wouldnt go out of 1st gear! NOT GOOD! there was a new code on the programmer that said lost communication w/ the powertrain. i immediately disconnected the chip and put the truck back to stock. however it is stilll throwing these codes :Fuel rail pressure. low voltage to pcm/ecm. Low voltage for boost. and glow plug #8. what do i need to do?? i kno i obviously need a new glow plug but what about the others? please help :(
