1 - 7 of 7 Posts
So, I got my new 285/65/20 tires on the stock rim or my 2011 Denali. No issue with that part.
I bought a tire calibrator (rough country) and it is worse then just leaving it stock in regards to the speedometer. I can tell (or feel like I can) difference on the shift points and overall better feel of the truck vs the stock tune.
I am very curious to know if this is just me thinking there is a difference, OR does this tire calibrator do more than just TRY to correct the speedometer because it fails unbelievably not doing anything with the speedometer.
Anyone know of a better speedometer calibrator or do I just leave it as is with the stock tune?
Currently it is the Rough Country Speedometer Calibrator # 90009.
When I went to the 19.5s I bought a Hypertech programmer that worked great.
2006 LBZ CCSB Leveled, Hypertech Programmer, 2008 LMM WT, 2008 Gasser WT
I've used Hypertech speedo calibrators on 3 trucks without issue.
Alright! Awesome I am going to return what I got and pick up the hypertech!
Start with the advertised diameter of the tire and check the truck speedo with a GPS speedo, then adjust tire size setting to fine tune it if necassary.
Discussion Starter #6
quick question if you don't mind, when the hypertech gets here. If the diameter does not work exactly do I go up in size or down in size get the speedometer to where it needs to be. Like if I go up in size does that make the speedometer go up or down?
If speedo reads too fast, reduce tire diameter.
If speedo reads too slow, increase tire diameter.
1 - 7 of 7 Posts
