I'm gettin ready to put 265/75/16 on my 03 dually. Does anyone know how big of spacers I will need in the rear? Also, will I need to get longer studs? Any help would be appreciated!
It all depends on how big of a gap you want in between tires. Eveybody prefers a different look, but I think you could get away with only using 1/2 to 1" spacers. Longer studs are not needed because the studs on the spacers will be just as long as on the actual rear end. And the spacers come with nuts
Where's the best place to get spacers?
i put 2 " on mine with 265 no problem good comfort gap between tires when towing and no stud trimming or anything just bolt on
ck ebay got a couple buddies runnin ones off of there with no problems type in 8 lug wheel spacer think they you can get a set shipped to you for around a hundred
later
hard to see but this is 2" with 265
Thanks! Sharp truck by the way!
