1 - 20 of 28 Posts
So my truck has been laid up for a while now with a case of the "I don't know what's wrong with me because I refuse to trip a code blues" and I could really use a little help. I have a log file with a bit of regular driving and near the end a very clear fault with lots of APP (throttle pedal input) and little woow nelly. If you would like to take a look send me your email and I'll send you the log file to take a peek at. :drink
i will check it out of you would like, still have my email?
Thanks Nate :drink
ill check it out too, doubt il see anything nate doesn't see but ill take a crack at it :)
Not sure you could handle the AWESOMENESS of the logs even when the truck isn't running right :neener
Quicker Then Brian!
i may not, if fellow forum goers fail to hear my uplifting posts from now until forever they'll know i've met my untimely demise trying to tame the untameable.
Banned
Hmmmm....Is it only on a certain tune?
Seems like the air flow is low, like the big turbo is not moving the air.
You baro right now in your area is about 106KPa and the log is holding 98KPa, is there a limiter or something? try removing BARO limiters and see if it makes changes..
June 4th, Todd is coming down to meet with me and another customer for a Diesel Tech Photo shoot. Hard to get good pics of a truck that doesn't run!
thats so sick! jealous!
How long until its a centerfold?
What does your tuner Nick say?
Discussion Starter #15
Discussion Starter #16
Nope.....every tune.
Give me a call good buddy and we can shoot the breeze.
Sorry, did I miss something:confused:
it could have been taken several ways, you may have unintentionally took a poke at him. im sure its a misunderstanding.
Maybe, I've been too busy to get on the forum much, so may have missed some drama.
I posted just what I'd recommend my tuning customers doing if they have a problem, call me and discuss. I'll then get them fixed up. No hidden poke or anything.
Sorry, I'll back out of it.
Discussion Starter #20
It's difficult to read emphasis into text.....sorry if I took it the wrong way.
Ultimately this is a hardware issue.....one I'm having trouble tracking down so I went to the forum for help hoping someone would be able to see the issue in the log file.
For the record.....I think it's the MAF sensor that's causing me grief :eek:
1 - 20 of 28 Posts
