1 - 9 of 9 Posts
With both my edge and bully dog on their highest levels I am losing fuel pressure at the rails. Was wondering if anyone has done any experimenting with inline fuel pumps other than the Fass fuel?
Hi, I'm Earth. Have we met?
I run just a off the shelf holley blue pump, that i plumbed and wired in myself, i could always maintain atleast 20k of rail psi. 20k still is not ideal but its alot better than say 12-14k!
Thats alot better than 9K. Thats all I can Keep at full throttle. Lets just say its cutting out a little.
i will look into the blue pump
Was wondering if you use the fuel pressure regulator that comes with the pump and what it is set at?
THey are self regulating @ 14psi, that is fine for most lb7 engines, for a lly i would cut it back to about 10psi. I just pulled the spring out of the pump and kept cutting bits off at a time untill it ran @ 10psi!
Thanks
Thanks for the info on the holley blue pump. I'm having excellent results. Completly different truck. Thanks...:drink
1 - 9 of 9 Posts
