Just got truck out of the shop for a weird, intermittent coolant leak and a starter grind. I had the flywheel and starter replaced, teeth were pretty ground down.
I also had a bunch of coolant system o-rings and gaskets all replaced since some were leaking and we had the flywheel plate off the back of the engine.
Here's the issue.... we found a VERY small external coolant leak from the front of the right head gasket and a slightly bigger (still small) external coolant leak from the rear of the driver's side head gasket.
I have been planning to replace injectors for a few months now. Work has slowed a little and now is the time I do alot of truck repairs, etc...
I would like to hold off on the head gaskets for 2 to 3 months, but still do injectors in next week or two. Is this a bad idea or should I just get it all done at once?
I have a few long trips coming within the next month or two for work and am thinking it would be better and I would have a little more extra cash for head gaskets then.
I just don't want to do the injectors and then everything get messed up when head gaskets are done.
Let me know what you think.... Thanks!
