1 - 9 of 9 Posts
I am working on an 05 LLY with 144k miles on it. It keeps going into limp mode with a p0087 code. I checked the balance rates with a scanner and injector 2, and 5 are out of spec. This truck just came from the dealership and they replaced these 2 injectors already and they are still high. The fuel filter has been changed twice since this started. Just looking for some advice on what to try. This truck is stock.
Check the fuel hoses by the driver's side of the trans-- There was a GM_TSB on this problem and also will set the 0087 code..
Its not tuned. ill do some research on the TSB
Bump anyone have any other ideas
I just got back on this truck today. while i was checking things out i had someone power break it, the motor mounts are terrible. I can tell it is pulling on the wiring harnesses on the drivers side. Is there any wires or fuel lines that could be my problem because of the motor mounts. Just wondering if anybody has ran into this before
Also have a p1093 code
1 - 9 of 9 Posts
