I got a 2003 GMC 2500hd. Its got a few things done to her but nothing much with the engine. When I drive it makes a clicking sound. When its in park or nuetral it doesnt make the sound. It will only make it when the truck is moving so I'm hoping it has something to do with the axle or drive shaft. the clicking sounds exactly like a rollercoaster when its going to the top of the ride. Thats the best idea i can give you. If you have any idea's at what it could be toss it out here.
Thanks
Thats usually u-joints going bad, probably in the driveshaft. Could also be rear end going out, but that is usually a whining noise.. Check u-joints and carrier bearing first
Thanks alot I will definitely check the u-joint cause it was squeaking quite a bit 2 weeks ago and it stopped so i didnt think anything of it. Hopefully it is cause I know thats a cheap fix.
Thanks again bud
