I just replaced my injectors, here is what I found out, after calling and talking to the rebuilders they can not get new solenoids so all most replace is the control valves and nozzles if you are lucky, I went with injectors direct, I ordered the Bosch remans with all the updates including new solenoids, control valves and nozzles. The cost is $1695.00 and included vc gaskets and all o rings and copper washers. truck runs like new, I also installed Nicktane adaptor with Cat fuel filter 2 micron 10750#, I found a lot of debris in the injector intake line area, the factory filter was bypassing, Hopefully this helpsGetting ready to order injectors. Does anyone now about Dieselogic's injectors are they any good.
Great to hear!!!!:neenerHaven't been here in a while, but though I owed an update to the forum. I had my injectors done by my mechanic. Purchased Lincoln Diesel injectors. Worked fantastic. Installed airdog 165, cat filter and fill with power service every other tank. The truck purrs like a lion and has power to match. Love this thing.
I know its been two years ago, but give us a call and we will get something figured out for you. Thanks for the kind words. We appreciate it.I will also say LDS injectors were priced very competitively. They were super helpful and top notch as far as customer service goes! Can't say enough good things about them along those lines. However, I bought and installed a whole set of 8 LB7 Bosch injectors part # 97729095 the ones off of the site for $1699. I also installed the Cat filter and adapter from them too. The filter is cheap and readily available at my local Cat parts counter so I change it 5k with my oil change. It was expensive enough and a PITA job so I wanted to do as much as reasonably possible to keep these injectors healthy. I was very meticulous with the install. I've rebuilt several motors, frame up Dodge Viper build, two different complete high end sand rail tear down and re-assemblies, and I've been a lead tech working on multi-million dollar semi-conductor machines for the last 20 yrs for Intel. Install is NOT in question and yet I have two injectors already failing after only 2 years and 25k miles. I'm not saying anything bad about LDS at all, please don't take it that way, that's not my intention. I just wanted to point out that even the Bosch OEM remans suck too! This design really is shitty apparently.
