My truck keeps dripping Tranny fluid . I believe it’s the pan gasket so I posted a picture to see if you guys agree. Also think it might be coming from the little circle spot in the second picture. What do you guys think ? What’s this part even called?
Where at on the pan is it most noticeable?
Sent from my VS988 using Tapatalk
The corner on the driver side , closest to back of truck
I think that circle piece is called a shift linking Seal? How can I tell If it’s that piece leaking or the pan gAsket ? Where do I even buy a seal like that ? Is there a special tool for it?
Have you check to see if you have fluid coming through the main wire harness that is on the passenger side of the trans. Could possibly be coming from there and running around the xorner to the driverside.
Checked there , that side is completely dry
