1 - 19 of 19 Posts
I have a 2011 GMC 2500HD and am interested in installing some cab length nerf steps, but only if it requires no drilling. I refuse to drill a hole in that area of the truck.
Can anyone recommend steps that bolt right up and don't require drilling? From searching the forum, sounds like N-Fab doesn't require drilling -- any others?
thanks.
Try Jegs.com and punch in part # 976-202227J in the search window. I have these on my 2004 1/2 ton and my 2008 Crew Cab Dually. Easy, no-drill installation and a great product. I am 250 lbs and they are very stout. If you have any questions, Jegs is open 24 hours a day. 1-800-345-4545
Thanks for the Jegs recommendation. Anyone else have any other recommendations?
I put Go Rhino's on my 08, just cab lengths and they required no drilling. Crappy pic... but you get the idea. It is a LMM so not sure if the urea tank or anything on the LML would cause interference not found on the LMM's
Discussion Starter #6
So I ended up purchasing the N-fab steps and all I can say is whoever designed this never looked at a 2011 2500HD crew cab of any kind. The bolt holes don't even come close to lining up with the brackets. There is no possible way this was designed for a 2500HD.
I have a call into N-fab to see what their response is. Guess we'll see how good their customer service is.
If you have a 2500HD crew cab, stay away from N-Fab.
Any news on the manufactures respond??
nerf bars
I would look for Westin they make bars for everything and the ones I got for my LMM bolt directly to the frame where the body bolts to the frame nothing touches the body at all
Oem ?
even OEM 6" oval has to drill into rocker... def side of-coarse
My dealer, is just getting seperate brackets, and using OEM and other brand bars. They use someone elses brackets to make it work without drilling.
I got some knock off Westin looking ones from Summit Racing...They worked fine just had to retighten them once. Other than that they worked great until lifting and going with AMPs.
nerf bars
repeat
id like to add a picture to show you mine, they are a GoRhino 3" stainless tube style, no drilling rquired and fit great. pretty quick install. I can tseem to figure out how to add pics properly though. ive tried on a few other posts and they dont show up properly (damn new guys eh)
I got some running boards for my truck made by Luverne. Several others manufacturers stated theirs would fit not fit 2011 diesels (due to the DEF tank I assume). The Luverne brand mount to the cab mount bolts. You take the big cab mount bolts out, place the mounting bracket and reinstall the cab mount bolt. I suspect the right brand of nerf bars could mount the same way without drilling.
Bringing this thread back to life. I'm looking for a set of nfabs that will fit on my 2011 lml. Apparently this DEF tank is a PIA in all sorts of ways.
Discussion Starter #18
I went with the nfabs for my 2011, but paid a shop to install them. Saved me a lot of headaches.
Thats going to be my next step if I cant find what I’m looking for. I hate paying for installation on parts, but this time it might be better.
1 - 19 of 19 Posts
