I have a 2004 2500HD LB7 all stock. I had new injectors(8) put in this weekend, on the way home my oil pressure dropped to 15# running and started running rough. I changed the oil and it had about 7.5 gallons of oil/diesel. The balance rates are good, no more white smoke out the tail pipe. has anyone had this problem before.
yep yep...
cp3 seal let go?
Im Superrrrr!
Betting a return line wasnt tightened all the way.
yep yep...
i bet your right, i forgot the LB7 injectors were internal, I didnt get one clipped down all the way on my lly and it made a mess.
yep yep...
pull the valve pan covers. you cant tell which one by your return rates. it just shows what the injector is returning it wont show where its going.
