1 - 1 of 1 Posts
Supporting Vendor
The XDP Duramax CAT Adapter with 1R-0750 Filter, Bleeder Screw & Spacer is an easy way to upgrade the fuel filter on your 01-13 GM 6.6L Duramax. The durable anodized filter adapter simply threads on to the OEM Filter Head and allows you run the more efficient and less expensive CAT Filter on your truck. For an even easier filter change, we also include a filter head spacer to give you more clearance for filter changes, along with an aluminum bleeder screw to replace the factory supplied plastic version that is commonly damaged during routine maintenance.
Features:
Increased Filtration
Lower Cost Filter Replacements
No Modifications To Factory Fuel System Needed
Includes: Anodized Filter Adapter with O-Rings, CAT 1R-0750 Filter, Bleeder Screw, & Filter Head Spacer
Link: XDP Duramax CAT Adapter with 1R-0750 Filter, Bleeder Screw & Spacer
1 - 1 of 1 Posts
