Im getting my rig up to par for towing a 5ther, new wear item steering components, refreshing 'er on the neglected maintenance, etc...
I have a edge evo on order, how mandatory is it that I get the EGT probe? Im floating around 349k on 'er right now.
I replaced my PS pump and I am still getting a whine, so I am chasing that down. Hopefully its just a crappy hose. Something I was wondering about is how difficult would it be to stop if the pump went out? ...I lost a belt due to being rushed out the door at the shop on base at closing time so I know how much of a bitch it is to steer. Braking didnt seem too terribly bad, almost like stopping a older car with no power brakes.
I have yet to chase down a oil leak that seems to be coming from on top of the bell housing, my guess from research is PCV or turbo oil line. It isnt too severe so it should stay ok as long as I keep my eye on the oil level.
Installing the new hydraulic hose trans lines is also part of neglected maintenance. What trans temps should I be seeing when towing? I know there are a lot of variables.
How necessary are tow mirrors? If I do end up needing some, do the stock ones dim like the regular mirrors do?
The truck already has a B&W gooseneck setup installed under the bed, Is it mandatory to get a B&W 5th wheel hitch? The RVK3400 is pricey, I am under the assumption that it is probably better to get the sliding hitch since I hace a short bed.
The trailer connector on the truck, is a round one, has some wires that are damaged, what is that one called and is there a test light I can get for it?
What and how exactly is the tow/haul button used and manual shifting?
I cant think of anything else that pertains to towing/hauling that needs attention and is worth mention on here but if anything comes to my mind or attention, I will be sure to post up.
Thanks for taking time to read and answer a noobs questions
