1 - 11 of 11 Posts
I acquired my father's O2 6 6 turbo diesel about 6 months ago having hazing issues at idle no loss of performance everything seems fine and not getting any codes any help would be appreciated
Welcome. Hard to say without knowing any details on your truck. Is it bone stock? Have the injectors ever been replaced? Have you had any testing done or do you have the capability to do them, especially balance rates?
Welcome to the DF! Common problem early on when the injectors are going south.
Welcome aboard.
Good ol LB7 but once u fix injectors they are solid. Mine ran really good with fresh injectors. Good luck to you and welcome
Discussion Starter #6
The truck is bone stock the only upgrade I know it's had to it is a 4in exhaust the injectors I do believe or stock as well and no lift pump
We also believe that my father ran unleaded gasoline in this truck we do not know how much and for how long
Needing a set of injectors is pretty likely but if gasoline was run it's hard to say what else might be going on and you'll probably want to have it checked out by someone with the proper test equipment. My first thing would be an injector balance test and I'd want to look for excessive blow-by since that is a common indicator of piston damage from running gasoline. I'd want to do a compression test as well, but I have the test equipment so am not paying to have it done. In all likelihood you just need injectors, at least based on it being a good runner.
Discussion Starter #9
Welcome to the forums! Definitely have the injectors replaced and update us for any changes.
I've already dropped the tank and had it cleaned the tank will be going back in this weekend and then I will be doing the compression check more updates as they come9
1 - 11 of 11 Posts
