1 - 9 of 9 Posts
I have a 2005 2500HD crew cab and I've replaced starter ignition and neutral safety switch and I still have nothing! I turn key and it does nothing! Can someone give me an idea???
Nothing at all? Any lights on? What made you make those changes to begin with?
Have lights dash lights everything except wont crank. It acts like maybe it would be in gear. I can jump solenoid and it fires. Can jump off at relay it fires. Turn key nothing
So what powers the relay that fires your engine? Make sure that the pink wire from your switch pin #5 to the BCM has power when you turn the key to start. If it does, your BCM should be sending a message to the ECM to start. ECM sends power to the start relay on the yellow/black wire to the control side of the start relay. Check that. This is what the wiring diagram for my 2008 model says. Check your STRTR fuse in the underhood fuse block.
Get a wiring diagram for your year at GMUPFITTER.COM, body builder manuals, then look for your year and model and get the Electrical manual (separate from the others) and follow thru the steps that would occur during the start process, see where you have power and then where power fails.
Reactions: Dustin186
Is the security message on? Is the check engine light on? Any codes in the ecm or bcm? Do you have a good crank request signal to the bcm and ecm?
Discussion Starter #7
So it turns out that whoever had the truck before me had bought it from a buy here pay here place. It had a gps tracking system in it and they wired it so bad that the wires were shorting out the box. Removed it and used good wire connectors and boom fired right up. Thanks guys for the suggestions
Well that's certainly different. Take any pics of their nonsense?
1 - 9 of 9 Posts
