I've got a 2017 with 125k miles on it now. It's been a reliable truck, but there are some problems you're definitely likely to encounter.
They seem to go through glow plugs much more often than other trucks; my 2017 has had around 10 glow plugs replaced over its lifetime. There was a software update released that may or may not have fixed this problem, and I haven't had to replace any in the 15k miles since I had mine updated.
Injector connectors have a high failure rate. You can buy replacement crimp-on connectors for around $50 each if you want to try a DIY replacement. I haven't had to replace any on mine yet, but it's just a matter of time.
The coolant reservoir has a built-in sensor that fails. When it does, the entire tank has to be replaced, and replacement tanks are around $100. Not a difficult job to do with some basic hand tools.
Modern emissions diesels also do better when driven at highway speeds for extended periods of time regularly. The DPF can clog up quickly otherwise, since it won't get warm enough to start a regen and clear out the collected soot. You will notice when a truck starts a regen in town, since it'll idle much higher and the burning diesel smell is much stronger, at which point you'll want to take it for an extended drive as soon as possible.
Other than that, they're good reliable trucks and they'll treat you right as long as you treat them right. Keep up on your maintenance, use quality diesel and DEF fluid, and you'll probably be fine.
