1 - 20 of 21 Posts
G'day folks,
Just obtained a 2004 Silverado 2500 CCLB that will be used to haul our 28' 5th-wheel. Seems like a great truck so far, it replaced a 1995 F350 CCLB. Did a lot of looking before getting this truck. Has 180K on it but still runs strong.
Waiting to go for a ride in my nephews 2500 as there are some noises that I am not sure are normal for the 6.6L LLY. Nothing major, but I like to know what I am listening to. :)
Stan
Welcome to the forum and welcome to the Duramax thing. When I first got my LLY, I was paranoid about every noise, temp gauge fluctuation etc. Having towed our 5th wheel approximately 20,000 miles in some of the steepest, hottest terrain, I don't worry about these things. If you haven't done so, make sure you replace the stock turbo mouthpiece with an AFE or LBZ mp, do a search on here for more info. Also, get an EGT guage if you're going to be doing lots of towing.
Welcome to DF. Truck should be good to go just do like what Ally said and prevent issues instead of waiting for them to happen.
Wiring harness on your alternator bracket tends to rub through the insulation, cut it free from the bracket, I would look into that and get gauges.
Sent from AutoGuide.com App
Welcome to the forum!
Welcome and congrats on your 04' LLY!
Thanks for the welcome and information (will be looking things up as soon as I enter this message). Just finished removing the running boards (safety issue when wet - to be replaced with 20" steps) and have charted all the RPO codes so I know what I am working with. Did see the truck has 4" exhaust front to rear while it was up on the lift.
Off to do research, and thanks again.
Stan
:welcome
Discussion Starter · #14 ·
Projected modifications for the new truck, my son works for LineX, so we will be doing a dark gray bed, rocker panel, fender flare, hood bra and front bumper LineX coating. Also a graphic to break up the solid white a bit. The graphic may change to be something that matches the graphics of the 5th-wheel to make it appear the graphics merge from the camper down to the truck.
Above is as the truck sits in the driveway (the running boards have been cropped off as those have already been removed.
Below is the 'after' of what it should look like.
Spoolin' Up
It looks good but When I did the raptor liner on my truck I went up to the body line. No regrets here!
Discussion Starter · #16 ·
Understand that. :) This is all just photoshop at this point -- subject to change....
I neglected to add the bedliner overlap on the outside of the bed also.
Spoolin' Up
I hated the all white on mine also so here is a b4 and after for you.
1 - 20 of 21 Posts
