do you think i did it on purpose ?why did you post this twice
x2,000I hope your not planing on running n2o on a stock trans
What happened to your truck when you sprayed it with a stock transmission ?x2,000
It will mean death for a stock trans.
I don't know. I wasn't dumb enough to try it.What happened to your truck when you sprayed it with a stock transmission ?
now you got me thinking....spray a 100 shot till 5th gear, let off and run fuel only til the end :rof :rof
Yes.on a serious note nitrous does have an effect on timing right?
ok thats what i thought just making sureYes.
You have to cut it back a bit. And crank up the fuel. You dont need as much timing because the fuel is getting burned no matter what.
No its not a good idea because there is no defuel. Its hard to explain until you experience it. It shifts real hard & fast with n2o on.Subscribing....really its not good to run NO2 on a stock tranny? is there anyway possible to do it?
you're not driving a 12v..the whole spray it till it dont smoke mentality doesnt apply.....you have to have a tune setup for itsmall shot? Meaning? For example my race tunes don't really have any smoke in them because my cp3 is a little weak so i don't see it helping me that much. Am i right? People always say keep uping the jets until u see no smoke... Right? Well if there isn't really any smoke in the first place what do you do loL. What is a safe pill considered and what hp range should it put someone at?
