I've got 4-hi but no 4-low... any one? Light just blinks and then goes to 4-hi.
TIA
Administrator
exactly...sometimes it helps to let the truck roll forward a little bit while doing it too.
the manual actually states that u need 2 be at a crawl in change the 4wd so that the gears can sync up. otherwise, the actuator in your t-case is bad and has to be replaced. good luck
I just took mine out wheeling for the first time last Saturday and ran into the same problem, this is my first electronic shifter. Turned out I just needed to shift into nuetral and let it roll back just a little for 4lo to engage.
Kevin
