Candace
It is apparent to me that you are not knowledgeable about our diesel trucks nor electrical systems. We all start that way and learn as we go. When you have 2 batteries in your truck, they are tied together and make 1 'bigger' battery and the voltage of each individual batteries will be equal to each other.If left long enough without charging, the voltage in each of them will equalize - the stronger battery being 'pulled down' to the weaker battery. When disconnecting cables in your truck, you need to remember that disconnecting something from one does not disable the electrical system overall - there still may be lots of energy in the other battery. When people talk of touching cables, you have to remember that if one battery is still connected, pos and neg, the electrical system is alive and active and touching the 2 cables from the other battery will cause a dead short and a BIG ONE. It will likely be like an arc welder, possibly explosive.
Took to dealer. They said no power to ecm. Wanted $900 to put in fuse block in engine compartment and then they could run further tests.
You should have found out why there was no power to the ECM. That could have been because there was a fuse or two blown. All power to the ECM goes thru fuses. Saying you need a new fusebox is just too simple of an answer. Maybe the dealer explained that to you, maybe not, but you said nothing of it. Maybe there was a broken wire between the fuses and the ECM. It should have been made clear to you. Most people just want to know what it takes to get their vehicle running and maybe that's what you wanted, but on the forum, we attempt to educate, pass on knowledge gained thru the years to others, so that they have more knowledge.
The dealer likely could have wired around the problem area of the fusebox and run the tests they wanted to run. Maybe they did that, maybe not. I doubt it. That would have been the best way to do the testing. Dealers love to have everything new, sometimes without good reason, so that they can test something else. Sometimes they will have you spend thousands of $$ only to find out that they failed to identify the real problem to start with and failed to do proper testing.It happens all the time.
