1 - 2 of 2 Posts
Went to 03 this morning and no crank, no glow plugs, no intake heater.
Relays are good and crank circuit and fuse powers up with key all ahead.
If you ground starter relay terminal in the relay control box the engine will turn over.
Power to glow plug timer but not signaling.
No power to fuel pump relay.
Any ideas or diagrams, seems like a main breaker, signal wire or fuseable link but cant find anything so far.
Any help would be muck appreciated.
There is a main fuse under the top of the fuse box in the engine compartment. You have to fuss with it and get top of the fuse block off. Check there first.
1 - 2 of 2 Posts
