I have a 2007 lbz. At idle my frp is perfect and when I elevate rpm in park but when I'm driving down the road and go past 3/4 throttle my frp is around 40psi lower than idle and it ends up setting a low fuel rail pressure code and sending the truck into limp mode. I have replaced fuel filter and the 2 soft lines coming in and out of it, the valve for the pressure check stem. And the soft line coming from the tank on the driver side. I have no fuel leak that i have noticed and I have had no luck so far with fixing the issue or even getting close. I am stumped. UPDATE: replaced cp3. Ran good for about 3 days before going back into limp mode with no throttle response this time. Went back in and replaced fpr, after replacing, the truck would crank but not start. So i went back in once agian anf replace both cp3 and fpr this time. Put it back together and its still saying it has 0 rail pressure. I have no clue what to do next
