Ok the diagram I was looking at shows that it gets powered up by the tcm do you have a diagram that will tell me wich connector on the ecm has this wire as I am also getting codes for no communication with tcm and fuel injection also shows fuel pressure regulator control circuit high when I put 12 volts to edu fuse all codes go away except loss of communication with tcm the codes are p0090 fuel pressure regulator control circuit high u0101 loss of communication with tcm and u0105 loss of communication with fuel injection control again when I put voltage to edu fuse the truck starts and the only code that remains is u0101 loss of communication with tcm
