1 - 7 of 7 Posts
I Have A 2005 Duramax And I Use A Dump Trailer To Haul
Debris With. I Recently Replaced The Battery In The Dump Trailer..... Without Thinking I Removed The Battery From
The Dump Trailer And The 2 Wires From The Harness And Set Them Down Inside The Battery Box. Then I Moved the
Truck And Trailer Without Insulating The Battery Wire From The Truck To The Dump Trailer Battery. Then Installed New Battery. Now The Battery Is Going Dead All The Time, It Used To Recieve A Charge When The Truck Was Running. But When It Isolate And Check The Positive Wire From The Harness It Shows No Volts. Here Is My Question, I Know I Blew A Fuse Of Some Sort, But I Have Checked Every Fuse Under The Hood And Dash.... Does Anyone Know Exactly Witch Fuse (Or Fuse Link) It Is, And Where It Is Located? This Is Very Fusterating, Thanks Dan.:help
It may have a dummy fuse in that position-- should be a 40 amp.
1 - 7 of 7 Posts
