1 - 12 of 12 Posts
I have a maf code that I can't seem to fix and now I have the intake air temp code. I have a brand new maf sensor and a brand new airaid synthamax air filter. This all started right after I got my new injectors installed. Like the title says I have no power until 2500 rpm and a slight miss at full throttle. Brand new fuel filter and airdog aswell
Whats your boost lookin like?
Boost is mid to high 20's. It feels like it's not making boost until 2500rpm but I have a mechanical gauge. The only code is p0101. I have researched this for hours on here the best solution I can find is to get an Efi tuned ECM with the maf rescaled in the tuning
Have u put it back to stock yet and ran it?
Discussion Starter #6
I can't I bought it with the intake on it and no factory airbox. I could try to find one at a junk yard or do a craigslist swap.
I meant tune back to stock with the 6 gun
Discussion Starter #8
I have and cleared the code it comes back within 5 miles. Weird part is if I unplug the banks all together it is in limp mode but still with just the p0101
Well I guess you can work around the p0101 with efi but It seems to me the filter might be the problem I got to looking it up and people who swapped back to factory cleared the code. Is that filter oil based?
Discussion Starter #10
No the synthamax is not oiled. I found a guy with a banks intake here in town I am going to give a try. If banks doesn't help I will try rescaling with Efi if that fails I will have to track down a stock airbox. Thanks for the input
No problem, good luck I hope you get it solved. Also one last thing i'd do is double check the MAF making sure all the wires are good.
Discussion Starter #12
does anyone think it could possibly be that my mechanic has the airdog set with too low of a pressure and the thing is actually starving for fuel. the more i think about it; it seems like a fuel issue to me. my mechanic actually told me he turned the pressure down on the airdog. the miss is only on level 6 under full throttle, and the ses light comes on much quicker on level 6 than stock.
1 - 12 of 12 Posts
