1 - 2 of 2 Posts
New to the forum here, will fill out sig and pic once I get a chance. Truck is an 07 LBZ. Just finished installing a new torque converter and transgo jr. Now the truck won’t shift out of park. The pin is in and the shifter moves through all the gears, but the indicator light will only illuminate park. If you put it in reverse it disappears for about 6 seconds, then gives me the p0700 code and re-illuminates park. Also the shifter leaves park without the brake being applied. Any help is appreciated, thank you.
Discussion Starter · #2 ·
Now the park light is flashing every few seconds or so. If it’s in drive when the light comes back on the truck will slightly jolt like it’s wanting to go forward
1 - 2 of 2 Posts
