Hello, I have a 2004 chevy 6.6 lb7. First there have been several mods, bd trans, 13 year turbo, glow plug delete. 10mm stroker, new cam and crank sensors and wing to pcm, fass system, filter bypassed, 20 over inj, pressure blocker, pcm new, trans neutral switch, all other parts within 1 year old or so on engine . I have had a crank no start for quite a while, was intermittent that the truck would just die found fuel issues , fixed them now got good flow , could get to run for a bit till throttle pedel was pressed then it would die, checked peddle and wiring -no issues and tested with known good part same issue, all wiring has been removed from wrapping and has been gone over very thoroughly, fixed all the issues I could find and even did full overlays for several due to pinning issues, now the truck just turns over and does not start... I have been on this 6 months now and I don't know what else to check..this does have tunning to , is there anything else I can look at prob out. Change parts. I'm not sure where to go.i have Alldata, snap on scanner,most of the specialty tools and reg tools for this job. Just needing some help,insite,more knowledgeable than me help .thnks
